12 พฤษภาคม 2024, 12:27:17 *
ผู้เขียน หัวข้อ:  Multi Map เมนูแหล่ม ๆ อีกตัวนึงครับ  (อ่าน 7588 ครั้ง)
-ได้รับ: 72129
4%
« เมื่อ: 03 ตุลาคม 2009, 23:13:24 »
PNA MENU (isolation from what is the navigator)
Program which, with the inclusion of PNA displays icons of any programs (and as a consequence of the choice that run)
Usually, to start navigation to the PNA (at least in Chinese) is used HBS.txt file in the root of SD card (Update: just used shell.ini (inside path to the program) or folder mobilenavigator \ mobilenavigator.exe (other options possible, should look).
So the archive file in the root of the SD card so that the file from the archive HBS.txt was at the root of cards (respectively Menu folder ibid.).
If you want editing path names (spelled out in the archive \ MMC_Storage \ Menu \ Menu.exe) is right for you is like a memory card.
If you have another system running on your browser, then simply substitute for zapusknoy file file menu.exe
+ Videoclip (as an example of one of the navigators (the menu is not very basic, but after clicking on the "navigation) Somewhere in the middle of the video)
http://ru.yo...=K6wf8oAU5is
Customize the program may be editing the file ADDONS.TXT
Configuring the ADDONS.TXT
[pre_init]
LangSyncOn = "\ \ name of your stick \ \ folder where all starts \ \ langsync.exe"
[pre_quit]
LangSyncOff = "\ \ SDMMC Disk \ \ PalmGIS \ langsync.exe"
[modules] - there is configured module's initial menu
Settings = "icons / settings.bmp", "Settings", 1 (as I understand, 1 - start, 0 - to open more)
Software = "icons / align.bmp", "Software", 0
Games = "icons / align.bmp", "Games", 0
Tools = "icons / settings.bmp", "Tools", 0
Tools here indicates that when you open a submenu [Tools] (see below)
rest by analogy
Multimedia = "icons / media.bmp", "Multimedia", 0
Navigation = "icons / files.bmp", "Navigation", 0
[Tools]
Setup PNA = "icons / settings.bmp", "\ \ ResidentFlash \ \ Settings \ \ Settings.exe"
You can explicitly specify the path to the icon on the menu button "icons / align.bmp" file located in align.bmp DATA.zip \ icons
or leave blank ", then softina tries to add itself to the menu button icon in the program is executed.
TotalCMD = "", "\ \ SDMMC Disk \ \! TOOLS \ TotalCMD \ \ CECMD.EXE"
Name is displayed on the button, in this case TotalCMD
[Multimedia]
Movie int .= "", "\ \ ResidentFlash \ \ BetaPlayer \ \ Player.exe"
[Navigation]
IGO = "", "\ \ SDMMC Disk \ \! NAVIGATION \ \ IGO \ \ NavnGo.EXE"
[Software]
2xCalc = "", "\ \ SDMMC Disk \ \! SOFTWARE \ \ 2xCalc \ \ 2xCalc.exe"
[Games]
7Colors = "", "\ \ SDMMC Disk \ \! GAMES \ \ 7Colors \ \ 7Colors.exe"
In the name of [modules], all other names of submenus can be changed to fit your needs.
You can also play with SettingsBackup.ini, appears to reflect the initial setup is available on a flash drive for IGO (some language and voice indicated here, the same is used), well and do not forget about DATA.zip \ config \ pocket_pc.ini "
7 "(480x234)
4,3 "(480x272)
3,5 "(320x240)
Addons menu from ShivakiGPS - More here.
 ;) Grin
« แก้ไขครั้งสุดท้าย: 04 ตุลาคม 2009, 01:51:26 โดย ที-เร็กซ์ » บันทึกการเข้า
-ได้รับ: 72129
4%
« ตอบ #1 เมื่อ: 04 ตุลาคม 2009, 01:43:37 »
ทำภาษาไทยใส่ได้ ปรับแต่เมนูได้ เพราะโครงสร้างเหมือน iGO เชิญรับไปต่อยอดครับ  ;)
-ได้รับ: 72129
4%
« ตอบ #2 เมื่อ: 04 ตุลาคม 2009, 02:04:36 »
แถม icon AmiGo 1 ตัวครับ
jammpoo
VIP เมื่อ 30/09/2009
ID number: 765
กระทู้: 85
Send Money to jammpoo
-ได้ให้: 95
-ได้รับ: 75
« ตอบ #3 เมื่อ: 04 ตุลาคม 2009, 10:49:38 »
ขออนุญาต กด ดาวมุมขวาบน ครับ  อิอิ
จากความรู้หาอึ่งของผม ดูแล้ว ใช้งานง่ายดีทีเดียวเชียวแหละ
« แก้ไขครั้งสุดท้าย: 04 ตุลาคม 2009, 10:54:00 โดย jammpoo » บันทึกการเข้า
« ตอบ #4 เมื่อ: 04 ตุลาคม 2009, 10:58:24 »
พี่ เล็ก หา autosputnic   มาให้เล่นหน่อยคร้าบ
อยาก ไป เที่ยว พระ จันทร์  เอ้ย รัสเซีย   บ้าง    Grin  Grin  Grin
« แก้ไขครั้งสุดท้าย: 04 ตุลาคม 2009, 11:04:11 โดย eos_1v » บันทึกการเข้า
PhotoGarage.net
VIP เมื่อ 17-10-2009
จำหน่ายอุปกรณ์กล้อง DSLR นำเข้าจากต่างประเทศ
ID number: 282
กระทู้: 62
$10.01 credits
Send Money to PhotoGarage.net
-ได้ให้: 33
-ได้รับ: 64
« ตอบ #5 เมื่อ: 04 ตุลาคม 2009, 22:53:32 »
เอาไฟล์วางไว้ตรงไหนบ้างครับ Huh?? นอกจากแก้ชื่อการ์ดให้ตรงกับที่ใช้อยู่
ansukman
มันก้อยัง งง งง
ID number: 213
กระทู้: 30
Send Money to ansukman
-ได้ให้: 153
-ได้รับ: 36
« ตอบ #6 เมื่อ: 06 ตุลาคม 2009, 16:40:12 »
อยากได้ icon เพิ่มครับ
มีใครจะกรุณาหน่อยได้ไหมครับ
ขอบคุณล่วงหน้าครับ
เริ่มใหม่อีกครั้ง กะ GPS
« ตอบ #7 เมื่อ: 06 ตุลาคม 2009, 19:13:07 »
เจ๋งมากเลยครับพี่ Grin
ขอลอง
iGO MULTI Loader สำหรับ Windows CE
iGO Discussion
ที-เร็กซ์ 4 5603 กระทู้ล่าสุด 15 ตุลาคม 2009, 16:31:40
โดย Novox
Decent 3.5 Multi Color
✄PiGGer✄ 0 2724 กระทู้ล่าสุด 23 พฤษภาคม 2012, 15:52:04
โดย ✄PiGGer✄
Hud multi display สำหรับ Android
thonau101 0 2263 กระทู้ล่าสุด 12 กุมภาพันธ์ 2014, 00:47:01
โดย thonau101
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.138 วินาที กับ 53 คำสั่ง
