06 พฤษภาคม 2024, 19:21:08 *
หน้า: 1 [2] 3   ลงล่าง
ผู้เขียน หัวข้อ: [เครื่องมือ] Beautiful Widgets v3.2 Update v5.7.5  (อ่าน 46840 ครั้ง)
« เมื่อ: 29 ตุลาคม 2010, 06:00:40 »
Beautiful Widgets
Requirements: Android
Overview: Beautiful Widgets is a set of widgets that run on the mobile Android platform.
Features:
- Nice looking clock with 12/24 hours support
- Multiple layouts and skins support
- Weather with realistic icons
- Celcius and fahrenheit temperature
- Automatic language detection
- Geolocation for the weather city, or the ability to enter the city name
- Automatic sunset/sunrise calculation
- High res graphics for WVGA Devices (such as the Motorola Droid or Nexus One)
- 1x1 beautiful Wifi/Bluetooth/Plane mode/Silent/Vibrate widgets to easily enable or disable them
- 1x1 GPS widget that act as shortcut to enable or disable location in the settings.
3.2 - 28th October 2010
- Rewrote the small toggle widgets into one widget, where you can choose the function. Please note that you will need to remove all the old widgets and replace them on the home screen.
- Toggle widgets can be skinned
- Toggle widgets can have their labels hidden
- Added a Mobile data widget toggle. This change the APN in order to deactivate the data (only known method to work)
- Added a 4G toggle widget for HTC Devices *only*
- Added a Weather 1x1 widget
- Fix a few bugs that made the settings confused between the choices of Google or Accuweather for the weather.
- Fix a bug with ANR when the phone is unlocked
- Fix a bug with weather refresh on unlock using Google weather (the accuweather values were used)
- Fix layouts for ldpi devices as well as landscape with the weather widget 1x4
- Workaround for the wrong graphics being used on widgets after an update from the market with new resources in the package
IMPORTANT: REMOVE AND RE-ADD THE WIDGETS IF YOU GET GRAPHIC BUGS, OR CLOCK ISSUE AFTER UPDATE
http://level...gets/weather
ลิงค์ครับ  Roll Eyes
very thank Diversity   สำนึกผิด
« ตอบ #21 เมื่อ: 05 กรกฎาคม 2013, 22:12:41 »
Update Beautiful Widgets v5.2.3 b15
What's in this version:
Improvement
 CPU usage
 Bug fixes
 Fix widgets digits shift
 Fix widgets digits missing
ลิงค์ครับ  เก็กหล่อ
« ตอบ #22 เมื่อ: 12 กรกฎาคม 2013, 05:42:33 »
Update Beautiful Widgets Pro v5.3.0
- 5.3.0 (Jul 11, 2013)
 New Trending tab in Theme Store
 Reduce widgets themes memory footprint
 Widgets use less memory
 Widgets refresh faster
 Temperature digit missing in forecast screen
 Warning advisories in forecast is truncated
 Fix widgets freeze
 Many crashes
ลิงค์ครับ  เก็กหล่อ
« ตอบ #23 เมื่อ: 16 กรกฎาคม 2013, 20:03:10 »
Update Beautiful Widgets v5.3.1
Widgets freeze HotFix
ลิงค์ครับ  เก็กหล่อ
« ตอบ #24 เมื่อ: 09 ตุลาคม 2013, 04:31:28 »
Update Beautiful Widgets Pro v5.4.1
What's new in this version
•New wind speed units setting : Beaufort, Ft/s, Knots, m/s
•Show next alarm in 4x2 Clock widget
•All widgets areas can now be used as shortcut
•New widget shortcut: Weather provider's website
•New widget shortcut: BW forecast
ลิงค์ครับ Smiley
« ตอบ #25 เมื่อ: 07 พฤศจิกายน 2013, 06:21:22 »
Update Beautiful Widgets Pro v5.4.2
What's new in this version :
•Fix Alarm Clock for Android KitKat 4.4 (New permission needed)
•Fix beaufort conversion with Weather Underground
•Fix "show Alarm" for 5x2 widgets
•Use Weather Underground by default for all new users
•Add minute shortcut for widget clock 2x1
ลิงค์ครับ Smiley
« ตอบ #26 เมื่อ: 06 ธันวาคม 2013, 06:31:21 »
Update Beautiful Widgets Pro v5.4.2b3
What's New:
- Fix Alarm Clock for Android KitKat 4.4 (New permission needed)
 - Fix beaufort conversion with Weather Underground
 - Fix "show Alarm" for 5x2 widgets
 - Use Weather Underground by default for all new users
 - Add minute shortcut for widget clock 2x1
ลิงค์ครับ  Smiley
« ตอบ #27 เมื่อ: 15 มกราคม 2014, 12:07:52 »
Update Beautiful Widgets Pro v5.4.3
•Fix touch areas in widgets
•Fix reorder locations1
Required Android O/S : 1.6+
ลิงค์ครับ  Ok
« ตอบ #28 เมื่อ: 01 กุมภาพันธ์ 2014, 20:15:15 »
Update Beautiful Widgets Pro v5.4.4
•Fix weather refresh issue
•Fix no city dialog issue
•Other bugfixes
ลิงค์ครับ  Ok
« ตอบ #29 เมื่อ: 07 กุมภาพันธ์ 2014, 07:14:29 »
Update Beautiful Widgets Pro v5.4.5 b5
ลิงค์ครับ
« ตอบ #30 เมื่อ: 11 กุมภาพันธ์ 2014, 07:20:11 »
Update Beautiful Widgets Pro v5.4.5 b6
ลิงค์ครับ  เก็กหล่อ
« ตอบ #31 เมื่อ: 13 กุมภาพันธ์ 2014, 04:56:56 »
Update Beautiful Widgets Pro v5.5.0
•Other bugfixes
ลิงค์ครับ  Ok
« ตอบ #32 เมื่อ: 20 กุมภาพันธ์ 2014, 04:50:19 »
Update Beautiful Widgets Pro v5.5.2 b2
What's New
Bugfixes
 Chines translation fix
ลิงค์ครับ  Ok
« ตอบ #33 เมื่อ: 03 มีนาคม 2014, 07:07:08 »
Update Beautiful Widgets Pro v5.5.3
Bugfixes
ลิงค์ครับ  เก็กหล่อ
« ตอบ #34 เมื่อ: 05 มีนาคม 2014, 07:00:18 »
Update Beautiful Widgets Pro v5.5.4
What's New
 Other bugfixes
ลิงค์ครับ  เก็กหล่อ
« ตอบ #35 เมื่อ: 23 มีนาคม 2014, 13:52:04 »
Update Beautiful Widgets Pro v5.6.0 b3
Recent changes:
 Beta 3: Fix for Kitkat clock not in sync
 New widgets: try the new color widgets!
 New color picker
 Multiple bugfixes
ลิงค์ครับ
« ตอบ #36 เมื่อ: 26 มีนาคม 2014, 05:08:41 »
Update Beautiful Widgets Pro v5.6.1
Fix issue on KitKat
ลิงค์ครับ  Ok
« ตอบ #37 เมื่อ: 26 มิถุนายน 2014, 06:15:33 »
Update Beautiful Widgets Pro v5.6.1b10
What's New
5.6.1b10
Netatmo support
Bug fixes
5.6.1b1
Fix frozen widgets issues
5.6.1b1
Fix issue on KitKat
ลิงค์ครับ  Ok
« ตอบ #38 เมื่อ: 12 กรกฎาคม 2014, 07:37:39 »
Update Beautiful Widgets Pro v5.6.1b12
What's New
5.6.1b10
 Netatmo support
 Bug fixes
 5.6.1b1
 5.6.1b1
 Fix issue on KitKat
ลิงค์ครับ  เก็กหล่อ
« ตอบ #39 เมื่อ: 16 กรกฎาคม 2014, 04:45:24 »
update Beautiful Widgets Pro v5.7.0
Netatmo support
Bugfixes
ลิงค์ครับ  Ok
« ตอบ #40 เมื่อ: 22 สิงหาคม 2014, 06:22:55 »
Update Beautiful Widgets Pro v5.7.1 b2
What's New
5.7.1b2
Improvements
Bugfixes
ลิงค์ครับ  Ok
หน้า: 1 [2] 3   ขึ้นบน
800 Beautiful Wallpapers Pack!
^SuRaYoOt^ 0 3309 กระทู้ล่าสุด 28 มกราคม 2011, 01:00:26
Beautiful Nature Screensaver << ธรรมชาติสวยๆ เอาไว้พักสายตา พักใจบ้าง >>
Other Software (PC)
qaser443 0 6230 กระทู้ล่าสุด 22 มิถุนายน 2011, 12:09:28
โดย qaser443
Beautiful Bamboo Forest [Screensaver 3D] ภาพพักหน้าจอเสมือนอยู่ท่ามกลางป่าเขา
Other Software (PC)
qaser443 0 2677 กระทู้ล่าสุด 09 กรกฎาคม 2011, 15:26:56
โดย qaser443
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.641 วินาที กับ 59 คำสั่ง
