Dimka - TomSoft 1.3.8 (a)
TomSoft Multifinkční strip (A, B, C)
A = data sheet of the target point + indicator ON / OFF radar
B = data sheet + transit point indicator ON / OFF radar
C = bar with other information such as GPS coordinates, compass indicator and ON / OFF radar
+ Possibility of remove waypoints (Long click on maneuvers)
+ Possibility of make screen shot of the screen (short handles no place under the maneuvers)
+ Larger Font data for navigation
+ Green - yellow arrows for maneuvers
+ Lakva Planning - improved planning screen (big thanks Lakva)
Lakva + TMC - TMC display indicators and signal strength (big thanks Lakva)
+ Added TomSoft settings for some options
+ Possibility to add additional buttons (BT, Telephone, Lakva Planning) to the quick menu and in the cockpit
+ Automatically delete routes shorter than ... "according to the setting"
+ BT + Phone Starting from the cockpit (an option in SYS.TXT)
+ Added more data to be displayed in TomSoft bar with optional parts
+ Added option to reset the TC
+ Views TMC or NV on the map
+ Greater transparency in the setting options
+ Possibility to run WiFi from the main menu
+ Resize "Preview křižiovatky"
+ Possibility of an optional setting display buttons on the main menu
+ Selectable preview intersection
+ Backup to restore the GJA
+ Information about the arrival time GJA
+ Views of the city on the map
+ View information on the recalculation of the route would GJA
+ Added bottom bar with buttons for route selection
+ Added TomSoft tachometer 2 (screensaver)
+ Sound cruise
+ ON / OFF raster maps directly from the cockpit (big thanks to the wires)
+ Possibility of additional Quick Menu
+ More details
Dimka - TomSoft 1.3.7 (a)
+ Adjustments for changes in the current author
+ Minor changes
Changes from the author:
+ Add another option for reporting TTS (something already functioning as a sonic fog, when the TTS voice reports that you can also add speed)
(You will need to update dictionary.voice, otherwise the choice of setting the TTS FOR unavailable)
+ Possibility to prioritize the TTS guidance or warning.
Dimka - TomSoft 1.3.6 (c)
+ Quick Edit menu, editing the menu directly from the dialogue (LONG-click on any button)
+ Add another quick menu (Quick Menu II.) ***
*** To view the Quick Menu button, you need to add this button in the settings of the map - see right menu. pictures
