My Amigo Skin V28Requirements: Works with most current editions of iGo Amigo
Overview: I made a skin that is based on the Amigo Ultra Skin by linknet. This only has the 480x272, 320x240, and
800x480(beta) resolutions. Among its features are voice alerts for red light cameras, expanded add via functionality, the ability to add phone numbers to favorites, the ability to edit favorites, the ability to run MortScript from the interface,
displays address of your destination or via as you reach it, a Go Home button, glass navigation and map buttons, and tons of bug fixes.
[break]
More Info:The skin comes in two flavors. Without key sounds (default), and with key sounds. Both are in the main download. This is due to the method used to play the red light camera ding only once instead of repeating it non stop as the original skin liked to do.
If you would like to change the sound that is made when a red light camera appears, place a wav file named "!alert6.wav" in a folder called "audio" that is in the same location as your data.gro file. You can use any wav from the audio package or make your own wav as long as it is 44100Hz 16 bit mono and named "!alert6.wav". If you would like to do the same for the voice alerts, create audio files named "!malered.wav", "!malespeed.wav", "!femalespeed.wav", & "!femalered.wav" and place them in the same audio folder.
To take advantage of the MortScript shortcut feature, place the "aautorun" package in the games directory such that the path to the exe is "\content\games\aautorun\Autorun.exe". The sample script will run coreplayer. Place the coreplayer package in the games folder or wherever you would like and adjust your pathes in the Autorun script accordingly. The MortScript shortcut is enabled through the advanced settings menu. To run coreplayer, press the MortScipt shortcut button. Wait for Coreplayer to start. Once you select your play list and start, you can minimize using the button in the upper left, and the music will keep playing. To turn off coreplayer, press the MortScript button again. You can also watch movies with coreplayer and the navigation commands will play in the background. If you were to try to play coreplayer by simply clicking its icon in the Games menu, you would not be able to minimize or listen to navigation commands while open. The MortScript icon in the Games menu works the same way as the shortcut. Realize also that you can do ANYTHING with this button. Just write the script.
V25:
- Everything in V24
- Expanded add red light camera feature
- Fixed issue with overlap of red light camera visual warning and speedlimit
- Added setting for picture viewer folder
- Added detour function to map controls
- Added standby and shutdown buttons for shutdown timer
- Added speed camera voice
- Added more transparent objects for glass mode
- Added option to scale the volume bar instead of making it the default setting
- Fixed delete saved route bug
- Added proper street sign colors for Israel
- Added 320x240 resolution for those that want to test (Thank you sbarro for doing the conversion!) Please PM problems. I'm still working on the icons.
V26:
- Everything in V25
- Added option to sort favorites by name or distance.
- Minor bug fix for favorites and home button.
- Holding down the info on the lower left will make the unit say the eta to destination instead it play whenever the info button is used.
- Added transparent road signs in glass mode.
- Ability to shift road signs down so that directions can be displayed.
- Made all glass transparencies uniform.
- Cosmetic bug fixes.
- Fully functional and up to date 320x240 resolution included (no longer in test mode).
V27:
- Everything in V26
- Bug fix for gear icon
- Added Itinerary
V28:
- Everything in V27
- Added Compass
- Bug fix for road signs shift
- Bug fix for show address
- Not a change but a fact of life: the transparency of the road signs only changes on a reboot of the program.
- Added a lot of cosmetic fixes for 320x240 (Thank You again sbarro)
- Added beta version of 800x480 resolution (please report what needs to be fixed)
Download Instructions:My Amigo Skin V28 (fixed): http://rapid....gro_V28.rarMirror:
http://www.m.../?d=DLTMOTARMirror:
http://ul.to/o7mzwdCorePlayer Package:
http://rapid...ayer_PNA.rarMirror:
http://www.m.../?d=X89EOJX1(read above about how to use this, thank you joking742)
Optional Audio Package:
http://rapid...10/audio.rarExcellent example of what can be done with mortscript:
http://www.m...?xn0nmykvgytCreated by miomoshe to run Total Commander.
