Thanks: gamethai showpicSchemes for Primo (in 480x272).
See more catches
Arsiv Downloads for Hiden:
Scheme Month / Month "Beanico v2.2
Presentation:
______________
- These schemes operate under Primo 480x272. For the rest, I have no way to test ... But the feedback from users indicate that the operation complies at 320x240 or 800x480. However the skies will eventually include some drawbacks.
- There are 12 files corresponding to the scheme 12 months of the year.
The main idea is to vary the elevation where there is snow in the mountains.
So, it is likely to stick to some ground truth,
it will be good to choose the following month or the month before ...
- For now, there is only one scheme for the night.
Origin
- These schemes are initially a mixture between the work of SAGFJG (with his consent) and color profiles Xerses published in the early hours of IGO8.
- Since version 1.2, color profiles are altered gradually.
- Since version 1.2, the skies were drawn by me in cartoon style.
Installation
Adjusting the tilt and zoom automatically:
_________________________________________________
I propose a new novel settings.
They can keep a close view of the crossroads
They enable a more panoramic during long distances without guidance.
This allows to take maximum advantage of landscapes, skies and terrain:
Add to sys.txt these lines:
[Camera2]
minZoom = 60
maxZoom = 180
minangle = 60
maxangle = 85
defaultzoom3d = 250
defaultangle = 80
CAUTION: To benefit from these settings,
you must set the view to normal in the card settings.
ลิงค์ครับ
Thanks to Beanico and kimyaci
