Thanks: gamethai showpicsk igo choup 8.3.6.9.Eur+ 05/06/2010
Compatibility with only 8.3.4.x
Resolution Compatibility:240x320, 240x400, 320x234, 320x240, 400x234, 400x240, 416x234, 480x234, 480x272,640x480
[Modification 8.3.6.9]
- Sélection/Déselction automatique du mode panic en fonction des pays à risque (SUI,AUT,GER)
- Ajout d'un nouveau type d'alerte, Stop possible, dans le Type 10 Zone dangereuse
- Ajout d'un nouveau type d'alerte, Descente Dangereuse, dans le Type 10 Zone dangereuse
- Ajout d'une icône spécifique pour les 5 types de zones dangereuses.
- Gestion des vitesses sur les T20
- Modification du script panic_mode.mscr
640x480 (by extrapolation) add in the sys.txt:
[Interface]resolution_dir = "320_240"
screen_x = 640
screen_y = 480
[Rawdisplay]
HighRes = 1
screen_x = 640
screen_y = 480
class = "landscape"480x640 (by extrapolation) add in the sys.txt:
[Interface]resolution_dir = "240_320"
screen_x = 480
screen_y = 640
[Rawdisplay]
HighRes = 1screen_x = 480
screen_y = 640class =
"portrait"480x800 (by extrapolation) add in the sys.txt:
[Interface]
resolution_dir = "240_400"
screen_x = 480
screen_y = 800
[Rawdisplay]
HighRes = 1
screen_x = 480
screen_y = 800
class = "portrait"800x480 (by extrapolation) add in the sys.txt:
[Interface]
resolution_dir = "400_240"
screen_x = 800
screen_y = 480
[Rawdisplay]
HighRes = 1
screen_x = 800
screen_y = 480
class = "landscape"As usual make sure to read the readme.txt before installation
ลิงค์ครับ
very thank kimyaci
