13 พฤษภาคม 2024, 21:07:44 *
ผู้เขียน หัวข้อ:  iGO MULTI Loader สำหรับ Windows CE  (อ่าน 5619 ครั้ง)
-ได้รับ: 72131
« เมื่อ: 15 ตุลาคม 2009, 13:43:24 »
Go apologize for îôôòîï if sho ...
Can someone handy, I decided to share.
Another "gadgets" for iGO, I called it:
1) iGO MULTI Loader Script
Background:
I have one assembly, decent work, no problem. But beyond the next assembly, some additional content that you want to try, but do not want to break the normal version.
What?
IGO created a new folder on the card, give a different name iGO_sborka. And another ...
You can create 3 folders.
I start loader and choose the version you want to download:
How it works:
Used MortScript, renames the selected folder in iGO8.
Names are taken from loader.ini, here is a sample contents:
[main]
separate = 0
[applications]
appl1 = "iGO8 New"
appl2 = "iGO8 sborka"
appl3 = "iGO8 my Old"
[folders]
Folder1 = "iGO8_new"
Folder2 = "iGO8_sborka"
Folder3 = "iGO8_my"
[time]
countdown = 6
separate = 1 - makes it possible to run each version separately, not renaming.
2) MULTI Loader Program
Just say: Requires Framework CE 2
AnalogichnoiGO MULTI Loader Script,
Instructions:
Works only on trying out KDE versions, you can set the path to the directory and the name of the directory itself (if iGO is at the root of the card, it should look like so)
workDir = "\ SDMMC"
workApplDir = "iGO8"
Unzip the archive to the root of the card, write up under her MULTIloader.ini
run MULTIloader.exe selected version of iGO and run.
Additions in version 1.1:
1) Ability to run each program (eg values: run = iGO8.exe) in their directory (if separate = 1),
If separate = 0, will be run only from WorkApplDir = iGO8, tentatively renamed the selected version.
2) When the value countdown =- 1, immediately run the current assembly, without raising the form.
Example ini FILE:
# MULTI Loader v1.1
# by VaLeRy Lyushkov © all2xyz@gmail.com
[main]
separate = 0
[paths]
root = "\ SDMMC"
workDir =
[applications]
appl1 = "iGO8 New"
appl2 = "iGO8 sborka-iGO8.3.4.102680 ot Eugene.Bout 17/09/2009"
run = iGO8.exe
[folders]
fldr1 = "iGO8_new"
fldr2 = "iGO8.3.4_sborka"
fldr3 = "iGO8_my"
[time]
countdown = 9
delay2run = 0
MULTI Loader v 1.1
pass: 4pda.ru
Credit : vallu @ 4 PDA.RU
« ตอบ #1 เมื่อ: 15 ตุลาคม 2009, 14:11:18 »
อ่านแล้วไม่เข้าใจครับ ช่วยอธิบายหน่อยครับ  : ฮือ ๆ
« ตอบ #2 เมื่อ: 15 ตุลาคม 2009, 14:21:53 »
ประมาณว่า ใส่ igo8  ไว้ ได้ หลายๆ เวอร์ชั่น ใน การ์ดเดียว ครับ
ใช่มั้ยครับพี่ เร็กซ์
-ได้รับ: 72131
« ตอบ #3 เมื่อ: 15 ตุลาคม 2009, 14:29:38 »
แม่นแล่ว..ว  ;)
Novox
ID number: 722
กระทู้: 173
$82.07 credits
Send Money to Novox
-ได้ให้: 40
-ได้รับ: 361
« ตอบ #4 เมื่อ: 15 ตุลาคม 2009, 16:31:40 »
อยากบอกว่า ทำเหมือนกันเลย
แต่เราเขียนใส่ MortScript แบบง่ายๆให้รันได้ก็พอ เป็น ListItem เลือกแล้วเข้าโปรแกรม
ไม่เปลือง mem ไม่ต้องโหลด shell เพิ่ม
อิอิ
ขอถามปัญหาเกี่ยวกับโปรแกรม igo poi loader
Custom POI
amper 4 5269 กระทู้ล่าสุด 07 ตุลาคม 2009, 10:38:45
โดย amper
Multi Map เมนูแหล่ม ๆ อีกตัวนึงครับ
ที-เร็กซ์ 7 7602 กระทู้ล่าสุด 06 ตุลาคม 2009, 19:13:07
ผมแปลงไฟล์ kml ให้เป็น gpx แล้วใช้ poi loader แปลงเป็น gpi มันไม่เป็นภาษาไทยครั
ธเนศ 0 4740 กระทู้ล่าสุด 30 กรกฎาคม 2010, 12:32:18
โดย ธเนศ
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.088 วินาที กับ 46 คำสั่ง
