Thanks: gamethai showpicdimkaWertVRV 1.1.39 26/05/2010
Skin diMka for 480х234, 320x240, 240x320, 240x400, 400x240, 480x272, 400х234, 416х234, 480x800, 800x480
only version 8.3.х(8.3.1, 8.3.2, 8.3.4).
Code
1. Corrections (introduced in 1.1.1938) - conversion when restarting the program the name of the intermediate points of the route in the coordinate format, regardless of the status of offroad-mode (thanks for Megaduck99 found inaccurate).
2. Corrections - if off the screen saver not working list of POI in the cockpit.
3. Corrections - coordinates of the cursor in vertical mode "2D-to the north" when you return to the cockpit of any state (thanks Megaduck99 found for any inaccuracy).
4. Fixed auto hide / display (depending on the distance to the maneuver), the list of POI in the booth for offroad-mode.
5. For 400_234, 416_234, 480_234, 480_272 increased the font settings of the data fields in the left menu of information by removing names of parameters.
6. Minor amendments to automatically change the transparency of the buttons in the cockpit.
1. We use data.zip from version 8.3.2 (no changes) and we use skin (no changes). Use in sys.txt: [interface] skin="ui_igo8"
2. We use data.zip from version 8.3.4 (no changes) and we use skin (inside the skin (inside the zip-archive) rename the folder ui_igo8 to ui_igo8_da). Use in sys.txt: [interface] skin="ui_igo8_da"
ลิงค์ครับ
Thanks : WertVRV for Skin
Do not forget to say thanks:
dima8389 - author of the original skin di / \ / \ ka.
Andron66 - a huge contribution to the graphic (bmp-files) of the skin.
Very thank kimyaci
