Becker Z302 Truck Navigation 8.5.2.122755
Thanks: gamethai showpicBecker Traffic Assist Pro Z 302,
the first mobile truck navigation system based on iGO engine.
Truck drivers can define profiles that are tailored specifically to the truck and payload. This profile includes details such as height, width, length, axle number, and weight which is then analyzed to calculate the optimal route.
Impassable roads, tunnels and bridges are then excluded depending on the profile data and possible, alternative routes are offered for selection in a map view so that the driver can choose the best route for him.
Thanks: gamethai showpicThanks: gamethai showpicThanks: gamethai showpicThanks: gamethai showpicThanks: gamethai showpicThanks: gamethai showpicOnly resolution supported is 480*272! :'( ( เราต้องมี จอ5 นิ้ว ซักวัน )
FileFactory:
http://www.r...cc5051c9b39f (Only German language)
My thanks to NorbertBL
Mirror (Multilingual):
http://www.m.../?d=V240TA5SInstallation:
Unrar and copy to SD
Change Sys.txt
Add Content
Thanks to SkyRocker!!
ผมไม่ได้ ลอง ใครลองแล้วเป็นช่วยเล่าให้ฟังด้วยนะครับ ขอบคุณครับ
ลองดู Data.zip ตัวนี้ด้วยนะครับ
and a data.zip with back buttonhttp://www.r...a25f46f8f517Thank to NorbertBL
