26 พฤษภาคม 2024, 01:25:38 *
หน้า: 1 2 [3]   ลงล่าง
ผู้เขียน หัวข้อ: [เครื่องมือ] Beautiful Widgets v3.2 Update v5.7.5  (อ่าน 47170 ครั้ง)
-ได้รับ: 69260
« เมื่อ: 29 ตุลาคม 2010, 06:00:40 »
Beautiful Widgets
Requirements: Android
Overview: Beautiful Widgets is a set of widgets that run on the mobile Android platform.
Features:
- Nice looking clock with 12/24 hours support
- Multiple layouts and skins support
- Weather with realistic icons
- Celcius and fahrenheit temperature
- Automatic language detection
- Geolocation for the weather city, or the ability to enter the city name
- Automatic sunset/sunrise calculation
- High res graphics for WVGA Devices (such as the Motorola Droid or Nexus One)
- 1x1 beautiful Wifi/Bluetooth/Plane mode/Silent/Vibrate widgets to easily enable or disable them
- 1x1 GPS widget that act as shortcut to enable or disable location in the settings.
3.2 - 28th October 2010
- Rewrote the small toggle widgets into one widget, where you can choose the function. Please note that you will need to remove all the old widgets and replace them on the home screen.
- Toggle widgets can be skinned
- Toggle widgets can have their labels hidden
- Added a Mobile data widget toggle. This change the APN in order to deactivate the data (only known method to work)
- Added a 4G toggle widget for HTC Devices *only*
- Added a Weather 1x1 widget
- Fix a few bugs that made the settings confused between the choices of Google or Accuweather for the weather.
- Fix a bug with ANR when the phone is unlocked
- Fix a bug with weather refresh on unlock using Google weather (the accuweather values were used)
- Fix layouts for ldpi devices as well as landscape with the weather widget 1x4
- Workaround for the wrong graphics being used on widgets after an update from the market with new resources in the package
IMPORTANT: REMOVE AND RE-ADD THE WIDGETS IF YOU GET GRAPHIC BUGS, OR CLOCK ISSUE AFTER UPDATE
http://level...gets/weather
ลิงค์ครับ  Roll Eyes
very thank Diversity   สำนึกผิด
-ได้รับ: 69260
« ตอบ #41 เมื่อ: 17 มกราคม 2015, 04:30:13 »
Update  Beautiful Widgets Pro v5.7.2
What’s new in this version :
Stability update
ลิงค์ครับ  Ok
-ได้รับ: 69260
« ตอบ #42 เมื่อ: 25 มีนาคม 2015, 18:57:47 »
Update Beautiful Widgets Pro v5.7.4
WHAT'S NEW
More fixes with RTL languages and Android 5.1
ลิงค์ครับ  Ok
-ได้รับ: 69260
« ตอบ #43 เมื่อ: 16 เมษายน 2015, 05:00:35 »
Update Beautiful Widgets Pro v5.7.5
What's New
Fixes for RTL languages
Other bug fixes related to Lollipop update
ลิงค์ครับ  Ok
หน้า: 1 2 [3]   ขึ้นบน
800 Beautiful Wallpapers Pack!
^SuRaYoOt^ 0 3505 กระทู้ล่าสุด 28 มกราคม 2011, 01:00:26
Beautiful Nature Screensaver << ธรรมชาติสวยๆ เอาไว้พักสายตา พักใจบ้าง >>
Other Software (PC)
qaser443 0 6463 กระทู้ล่าสุด 22 มิถุนายน 2011, 12:09:28
โดย qaser443
Search Beautiful Girls from your town for night
Garmin Discussion
patkam 0 75 กระทู้ล่าสุด 20 พฤษภาคม 2024, 15:24:47
โดย patkam
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.174 วินาที กับ 42 คำสั่ง
