17 พฤษภาคม 2024, 05:46:13 *
ผู้เขียน หัวข้อ:  Smart IR Remote for Galaxy S4 1.2.4($9.99)  (อ่าน 2301 ครั้ง)
e20jbf
e20jbf@gmail.com
ID number: 24740
กระทู้: 75
Send Money to e20jbf
-ได้ให้: 528
-ได้รับ: 134
« เมื่อ: 24 มิถุนายน 2013, 16:09:09 »
Current Version: 1.2.4
Requires Android: 4.1 and up
Category: Tools
v1.2.4 update:
- Added more languages: German, Spanish, French, Japanese, Korean, Norwegian, Romanian and Swedish
- Added Resizable widgets! *only guaranteed to work with the default launcher
- Added short tutorial which shows on first run to present the most important features
- Added XBox 360 support, improved remote setup process, navigation between many remotes (try pressing the remote name), other minor improvements and bugfixes
Overview:
You can now use your phone as an Infrared Remote (IR Remote)
Why should you need to use more than one remote for all the devices you own ?
With Smart Remote for your Samsung Galaxy S4, you can add, create and customize any number of remotes, combining controls from any of your existing remotes. Imagine a single remote on which the CHANNEL UP button controls your Set Top Box from your TV provider, the VOLUME keys control your home theater system and the arrow keys control your TV’s menu.
On top of all that, since you’re holding a phone, why not use some of it’s unique features?
AIR GESTURES – exclusive to your phone!
Simply leave the app open, and wave your hand above your phone to change channels (left to right) or volume (up and down)
AUTOMATIC MUTE WHEN YOU GET CALLED
Don’t you hate it when you receive a call but can’t hear the other person because the TV is too loud? Now, Smart Remote can automatically mute your current device when someone calls you.
DYNAMIC VOLUME – BETA
Smart Remote will automatically turn down your volume when there are sudden high-volume sounds (think movie explosions), or it will turn up your volume when the sounds are too low to hear (think actors’ voices not being loud enough)
MACRO COMMANDS
Send multiple commands at the press of a single button!
With infrared – IR Blaster – already included in your phone, why shouldn’t you make the most of it? Smart Remote can control your TV, Set Top Box, Lights, Projectors, etc.. Virtually anything that has an Infrared Receiver can be controlled by Smart Remote with the correctremote codes. And we’re working 24/7 on adding more!
Why not get rid of your TV remote, set top box remote, and home center remote, all at once ?
# Please note that due to the large queue, it normally takes 1-2 weeks to add new devices to our database after you report them
# Please note that due to Galaxy S4 hardware limitation, automatic learning isn’t possible
รูปที่1
รูปที่2
Download via Google Play:
  Smart IR Remote for Galaxy S4 1.2.4 on Google Play
https://play....remotefairy
Download :
https://www....zh2ifrsc86si
Remote สั่งถ่ายรูปจาก Smarphone รองรับมือถือทุกระบบ ราคาเบาๆ
P.A.NAVIGATOR
P.A.NAVIGATOR 3 7298 กระทู้ล่าสุด 13 สิงหาคม 2014, 15:59:54
โดย P.A.NAVIGATOR
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.023 วินาที กับ 36 คำสั่ง
