12 พฤษภาคม 2024, 09:07:31 *
ผู้เขียน หัวข้อ:  Skin Primo Sbertaud13 iPhone iPad 1.2 EUR+  (อ่าน 3639 ครั้ง)
« เมื่อ: 22 กันยายน 2011, 02:51:09 »
compatibility;
iGO Primo 2.0.6 & 2.1
iPhone 4 / iPad 1 & 2 / iPhone 3G
iOS 4.3.3 or less (The integration of radar txt file does not work with a newer version)
Skin in French only
New in this version
1.2 EUR +
- Added new parameters in the parameters of the skin
- Adjustments various & diverse
- A press on the image of the first maneuver repeated the next maneuver.
- Long press on the icon menu allows quick access to the parameters of skin
installation Manual
- Connect to your iPhone via SSH or other
- Go to "/ private / var / mobile / Applications / xxxxx-xxxxx-xxxx-xxxx-xxxxxxxxxxxx / iGO_Myway.app"
- Copy the branding.zip (2.0.6 or 2.1 depending on your version) of the skin (overwrite the original branding.zip)
- Copy the folder content of the skin to have the TTS voice changed
If you want to use sounds wavs for safety camera
- Download the file "Sounds for speed camera alerts for skin Mioskins Primo" on Mioskins
- Unzip (on your PC) the file "sk_primo_audio_radar_mioskins_wav.zip". you get a folder "Audio".
- Copy the directory "audio" directory iGO_Myway.app
- Start Primo. Enjoy !!!!!
Installation Radar  File
The easiest way is to use one or more txt
It should copy the / file (s) txt here: Documents \ content \ speedcam (Documents is the same as iGO_Myway.app)
Start Igo and enjoy
sys.txt
I give you the sys.txt I use
[folders]
secondary_app ="../ Documents / "
[warning]
speedcam_maxdistance_from_road = 150
speedcam_max_angle = 50
speedcam_max_lookahead = 1000
[sound]
ding = 0; I do not like ding
queue_length = 200
[roundaboutcam] I want to turn in roundabouts
enabled = 0
centery = 50
[3d_config]
disable_roadsign_navigation_mode = 1, the choice to display the names of streets or roads bubble
0 = inside streetName textballoon
1 = streetName embedded on the streets.
[3d]
max_pois = 10
max_pois_on_horizont = 1
max_speedcam = 10
max_speedcam_on_horizont = 1
max_camera = 10
max_camera_on_horizont = 1
recalc_voice = 0; no announcement during a route re-calculation
Link Download
http://zidof...e.com/UINRfM
Thanks to Sbertaud13 and Kimyaci
ที่มา  www.igo8navigation.com
iGO: Skin Sbertaud13 Iphone 3.0 EUR+Keyboard Thai
iGO for iOS
Higps 8 9545 กระทู้ล่าสุด 19 ธันวาคม 2009, 00:10:31
โดย Higps
Skin Sbertaud13 v3.7 สำหรับ iGO for iPhone 1.1
iGO for iOS
Higps 6 6606 กระทู้ล่าสุด 23 กุมภาพันธ์ 2010, 20:09:43
โดย emperorofgod
Skin Amigo Sbertaud13 V6.8 EUR+
tin_43257 1 4818 กระทู้ล่าสุด 25 เมษายน 2010, 09:51:09
โดย ₪๐StemCell๐₪
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.038 วินาที กับ 37 คำสั่ง
