Sensor music player 1.432
โปรแกรมเล่น/หยุดเพลงเพียงยื่นมือหน้ากล้องประมาณ 0.5 วิ จะสั่งหยุด/เล่นเพลง (สำหรับคนมีเครื่องกล้องหน้า)
หรือแค่ให้กระเทือนเครืองก็เปลี่ยนเพลงถัดไป
“pocket” calibration tool improvements
bugfixes
Please update your review in the market if you like this version better
Overview:
Intuitive music player, using fun, useful and innovative controls.
Using exclusive algorythms, this app allow you (mainly) to skip songs without using your fingers nor the screen, depending on the situation.
5 easy-to-access modes are available :
- Fly over : Pass your hand in front of your device (5cm max) to play/skip current song. Hold it 0.5s to pause. The proximity sensor we use is generally located around the device front speaker.
- Pocket : Lock the device, put in your pocket, slap it to skip current track.
- Hammer : Put the device on a surface like a table, hit the table to skip current song. WARNING: using the device loudspeaker can produce enough vibration to fire the action !
- Sensors disabled : Sensors are disabled, you can only use buttons to control the player.
- Custom : In case you feel the need to use different sensor settings. Set wich sensors you want to enable, set sensitivty and your own action for each sensor events !
cr:apktops
