บล็อคเบอร์ด้วย BlackList Pro v2.8 BlackList Pro v2.8
Requirements: Android 2.0+
Overview: A powerful call and SMS filters on Android phoneThis is an advanced call/sms filter tools. Create a black list and stay safe with your Android phone. This is a simple app, but rich and powerful features to manage unwanted call/text message from anyone.
This app works with per caller ID (incoming number) basic. Caller Ids can be organized into blacklist, or exception list and configured blocking options. Here are a list of features:
*** Recent update has a bug that does not show setting popup on some phones, try a press menu key > Setup.
*** NEW ***
- Schedule to turn on/off (PRO)
- Block MMS (Pro)
1. Blocking:
☆ Block call/text/MMS messages for a blacklist (a list of numbers)
☆ Block call/text/MMS messages for private numbers (no numbers, no caller id), numbers not in my contacts
☆ Block call/text message for pre-/post-fix numbers
☆ Exception list (don't block list) (PRO)
☆ Text filters by plain text or regular expression, prefix-matches, postfix matches.
2. Manage blacklist and logs:
☆ Options for an incoming call:
- Turn off ringer
- End call
- Optionally "pick up then hang up" (change in app's settings, may not work on 2.3+)
☆ Advanced number matching mode including exactly, start with, end with, contains, regular expression
☆ Widget option (can be set up from app's settings or widget (press HOME/menu/Blacklist/widget)
- Block numbers in blacklist excluded exception list (regular mode)
- Block all numbers excluded exception list (very useful when you are in vacation)
- Block all numbers (useful when you are sleeping)
- Turn blacklist off
- Auto SMS reply for blocked calls
☆ SMS blocked with/without logs
☆ Option to clear blocked missed call log
3. Configuration
☆ Schedule to turn on/off (PRO)
☆ Import contacts/call logs/ sms into a black list or add a custom number (not in your phonebook)
☆ Easily manage logs (sms back, call back, search, delete, restore, disable (PRO),...)
☆ Disable/enable logs (PRO)
☆ Password protection (PRO)
☆ Enable/disable block notification
☆ Backup and restore blacklist settings
4. Widget
☆ Quick access widget to change block options and configuration
☆ Auto-reply counters
5. and event more:
☆ Auto reply pre-defined templates
☆ Change widget themes
☆ Invisible blacklist icon (Invisible)
☆ Quickly add last call/text number to blacklist/exception list
Bug report and enhancement request:
☆ Drop a few line to
me@baole.org* PRO: Pro version can be purchased on Android Market
* Invisible: Invisible version likes Pro version, but it has an icon and a name differe
* Note: to enable pick up then hang up feature, go to setting/pick up then hang up
5. FAQ
☆ Why caller is sent to voicemail: Block a number with "end call" and turn "Pick up then Hang up" OFF
☆ Do not send to voicemail: Block a number with "end call" and turn "Pick up then Hang up" ON
☆ Issue report: Email to
support@anttek.com6. Other
☆ Video demo:
http://www.y...=6bBaOCuPjRA☆ Screenshots, roadmap open issues:
http://antte...-for-android☆ User Guide:
http://antte...?page_id=231☆ Community support:
http://getsa...k_blacklist/Note:
- MMS: Multimedia Messaging Service
- Text ~ SMS: Short Messaging Service
What's in this version:
v.2.8
Add our Store
Add Hebrew
Update language packs
https://mark...blacklistproลิงค์ครับ
Mirror
