Thanks: gamethai showpicGJmpp v1.6 : 480х272 : 10.06.2010
1. Not much has changed manual speed.
2. Now the speed pad turns red, when there is over speed (manual speed)
3. Added settings reminder of over speed (manual and standard) - beep again after a fixed period of time.
4. Changed sound over speed.
5. Added multidraw route (displays all routes at once).
6. Added dynamic pad next street.
7. Added the sign of restrict turns and adjust transparency.
8. A lot of technical repair.
9. 2010.06.08 Fixed show speed per miles on menu pad.
10. 2010.06.08 11:30 Fixed DA and R. turns conflict.
Using skins:
- Downloaded the skin, day and night, as they are in the zip, place in a folder Primo / content / skin (if necessary - to create a folder and if the downloaded skin in RAR-archive - unzip and took out a ZIP-archive)
- Run the program, select the skin (set-display [More> Settings> Display])
- If necessary to restart the program
- If the skin is not listed, the possibilities are: no skin in the folder, the skin is not in ZIP-archive or the skin package is unpacked, the skin is not suitable for your permission or your version of Primo.
มาใหม่แทบทุกวันเลย
ลิงค์ครับ..
very thank kimyaci
